Well, the 5.3s up here I'm seeing for $750 and up, and the 6.0s are about $1,000 and up. I did my search using car-part.com, 2002 gmc/chevy 1500 (1999 up).
Roller406Bu said:Excelerater said:this is the best swap to make IMO right now......
why dont you let our readers know in a little more detail
whats involved with getting one of this installed and how
you are going to fire it up ?
How does the ignition work with a carb,how do you set the computer
or are you fabbing something totally different
I dig it,these motors can be bought pretty cheap and some are all aluminum which is very apealing
I've listed what motor mounts to use and what pan will work with no modifications...Tci makes a converter now that bolts right up to a 350 turbo transmission, I have one. Its a 36-3800 stahl..If you want to use your existing converter you have laying around you can use spacers and make it work.
That little red box you see in the pics is the brain of the operation, it tells the coil packs when to fire, and also reads the cam, and crank sensors. Timing adjustments, 2-step, rev-limiter are all adjustable thru your laptop with this box. The msd comes with 6 plug in chips with different tunes, or you can make your own timing curve. ls1tech.com is good place to learn about these motors, they are extremly easy to work on....
Doober said:Looks awesome I'm glad to see another Gen III motor in a G-body. I'm also kinda curious (if anyone else knows please chime in), do the stock manifolds have any fitment issues? I read some time ago that the Vette manifolds (at least) are pretty good on power, but I'm not sure what level they start becoming a restriction. I've been doing some reading on the LS1 in general over @ LS1Tech, and I think it's my new direction for what I want to eventually do with mine as well (I didn't realize how inexpensive the motors are).
Roller406Bu said:
