81 Malibu Tilt Swap
Chevys_Only
11
Altoona, PA
My malibu didn't have a tilt steering column, I found one at a local yard from an "83 Caprice Classic. It was the right color and had the correct turn lever so I got it. Just an FYI for anybody looking to use a B Body column in a G body car, it is not a bolt-in swap. The column is the correct length and the upper mounting bracket is in the correct location, but the mounting plate at the firewall is incorrect. I had to remove the B body mounting plate from the Caprice column. Then remove the plate from the G body column and install it on the tilt column. It wasn't a major headache, but was more work than I expected and did require cutting and welding. The shift lever is a little different also which required modifying the rod down to the transmission. A simple column swap should have taken about an hour and a half, I had about 4 hours getting this done. One plus, the original column was used with a 3 speed automatic and didn't have enough travel for the 700R-4, the caprice was equipped with a 700R-4 and this column has the necessary travel to select each position with the shift lever.
4,701
32
That is good information about the column parts interchangeability. It always feels good when a project goes well.
You could also disassemble the column, separate the 2 sleeve tubes, insert the Malibu lower tube, and reassemble. You need a press to reassemble and you need to take measurements before disassembly to you can reassemble at the correct length.
