Hey all.
I recently decided it was time to pull the heads on my 83 Malibu 3.8l 229 V6.
I drive this baby back and forth from Northern Wisconsin to Georgia about 6 to 12 times a year. Been reliable as heck. Always kept up on fluids, and changes. Been a great car. Got it with 96k original and I've put on about 30k in the year and a half I've had it. It was running rough for the guy that sold it to me so I checked all vacuum lines, rebuilt the carb, replaced the fuel pump, plugs, wires, and tightened all the fuel connections. Ran like a champ. Changed out steering box, all wheel bearings, calipers, rotors, upper and lower balljoints, inner and outer tie rod ends, center drag link, pitman arm, sway bar links, shocks all around, new door hinge pins, new door gasket seals, and a bunch of other little things I can't even think of. Basically, I want to have this car for a while. It's an 83 which is the year I was born, and I've always LOVED G-Body cars. My first two cars were 78 and 79 Monte's. Crashed one, and the other was stolen.
Sooo...
Out of nowhere I got a steady misfire in Cyl-6.
I've known for a long time that the heads needed rebuilding. Dollar bill trick at the tail pipe was more like the dissapearing dollar bill trick. It seemed to suck the bill against the exhaust pipe as much as it blew it away which was the worse it's ever been.
Figured bad exhaust valves and have been putting it off.
Car ran like a 15 year old 2 legged dog.
Changed plugs, wires, and dist. cap.
Miss was still there.
I figured "Yup, there goes that exhaust valve". Figured it burned all to hell so I didn't drive it and decided to take off the heads since I KNEW they needed to be rebuilt anyway. Didn't do a compression test #-o
Figured it HAD to be a burnt valve and since pulling the plug on the #6 cylinder made absolutely NO difference in the engine I figured I had it nailed.
Pulled the head and the valve showed minor burn. Only that valve leaked when I filled the runners with kerosene, and just BARELY. It wasn't a hole or a missing a good amount of metal like I was expecting. So I pull the other head thinking the other head must be REALLY bad. Other side all valves leaked kerosene. Intake, and exhaust. Intake valves leaked more than the exhaust so that spun me a bit.
Either way, I ordered 2 remanufactured heads for less than what they wanted to reman one of mine here locally.
While taking the intake manifold, and heads off I noticed more than a few loose bolts. No leaking of coolant between the gaskets so I was lucky to catch that. I thought maybe the loose intake manifold bolts could cause the engine to run crappy, but not so much on just 1 cylinder. Thought about it some more, and the vacuum port for the vacuum modulator runs right into the runner of the number 6 cylinder. Had some electric tape wrapped around it to hold it on.
Guessing that was probably the misfire problem, but I'm no mechanic. This is the first sbc I've ever taken apart. I've messed with all kinds of engines and am not afraid to jump into whatever and 9 times out of 10 I can get it fixed.
Also, the intake manifold EGR ports were CLOGGED. I don't mean a little. I mean SOLID PACKED for a good 2 inches. Ports on the heads were about as bad. I have had to run higher octane gas, or retard timing to avoid ping ever since I got the car. I figured it to be carbon buildup in the combustion chamber.
The EGR valve was disconnected when I got it, and I would REALLY like to get it operating again. From what I hear it cools the engine, and keeps detonation down which I would guess would increase MPG since I could stop running retard timing and maybe get some advance in there. The problem is, I've ordered a new EGR valve(the old one has a bad diaphragm) BUT I don't know how he heck to hook the thing up. I know how to put it in, but I don't believe it should go straight to a ported vacuum source. Most of the emissions stuff is gone. I'm not sure how to run the vacuum to it. I have a ported vacuum switch on the intake that I think is used for that, but I'm not sure what else I'm missing. Some kind of a solenoid I would think.
If anyone has any info on hooking up my EGR and getting it to function properly on a 229 3.8 I would give my pinky finger to hear it.
This is the only diagram I could find, and it's not that clear. Maybe I just don't understand it. Like I said, I'm no mechanic. I believe it shows the EGR coming from the Evap Control Solenoid. I don't have that. Wouldn't know where to start hooking it up unless I had a bit of help.
Thanks for checking this out. I'll get some pics up of the car, heads, engine block and all that tomorrow.
Sooo...
