Front Control Arm Shafts Upper Control Arms
colin
78
Hi Im replaceing my upper front bushings on my G body does any one know how to remove the shafts that run through the bushings so they can be replaced im using the Global west bushings they use grease
Betcha618
327
coram, NY
You have to remove one of the bushings then the shaft comes out. Also when installing them you have to put one bushing in then put the shaft in then the other bushing. the bushings are what holds the shaft in.
colin
78
so i wont be able to press them out ill have to cut them out?
colin
78
Moroso Trick Springs
Does anyone know the front weight of a malibu with a big block I removed my engine before I weighed the front and I need to order the correct springs ....Thanks
IIRC, the bushings are flared after installation. You need to peen the flared ends flat before you press them out.
Betcha618
327
coram, NY
No you don't just use an air chisel and hit them out. i do it all the time.
colin
78
They came out easy as pie couple of good wacks with something solid ,Now my next question is do you think I should use the global bushings on the lower ones as well ?
do the bottom ones come out as easy as the upper ones ?they are in good shape ...Im wondering if an upper set alone will keep my control arms from binding when i launch the car ....the top ones were real stiff i could barely move the arm
Betcha618
327
coram, NY
If you already have the front end half apart you might as well do all of them, they come out just as easy , there's no shaft, just press them out and press them in. Don't go past the shoulder on the bushing!!!! I've seen ppl do that and ruin the control arm.
