iroc steering box upgrade
jeff5347
Member
May 7, 2015
9
Hey guys I'm looking to do a steering box upgrade for my 79 Malibu. I can get a 91 iroc box from a friend but not sure what else is needed to finish the job. I know I can do the jeep Cherokee steering shaft upgrade but will this work with an iroc box? Where can I find adapters for my stock pump to fit the new box and do I need to do the valve mod on the stock pump. Yea lots of questions but don't want to get stuck in the middle of the job. Thanks guys
1981Regal
1,274
Cincinnati, Ohio
Not positive the pitman arm will swap but the box will bolt up. I would hold on to the stock pitman arm just in case.
4,700
32
You will need a pitman arm for the Malibu; it is not the same as the Camaro. If you have a 605 box, you will need to source a new arm. If you already have an 800 box, you can reuse the arm from the Malibu.
jeff5347
Member
9
Well I got everything installed. All new tie rods , center link, idler and got the box and new pump in. Works great. Have just under 2.5 turns. A lot tighter feel.
I thought I had. "Sticky" with all the steering box retrofit info...
