Leaking from the timing cover
lilbowtie
1,736
Canton Mi.
There is a treaded hole to the passenger side of the timing cover that is used to hold the fuel pump rod in place to install the pump and its open to the crankcase - do you have it plugged ??
78elk
1,294
81
Mountain Home Id
Thanks. I think so, but I'll check. The oil leak is in the center of the car. Does that hole leak to the inside of the block?
78elk
1,294
81
Mountain Home Id
Thanks that's good to learn. Mine is leaking from the pan gasket. I'm going to get a new one. Felpro warrants them.
