I need to know what everyone that has kept their motor EFI what they are running for a fuel system.
buhack said:if you want to run stock parts, a fuel pump from a 95 chevy 1500 with a 350 has the correct flow and pressure for the application, fits perfectly into a stock injected hanger too.
if you plan on modding the engine go with the aeromotive setup.
Doober said:buhack said:if you want to run stock parts, a fuel pump from a 95 chevy 1500 with a 350 has the correct flow and pressure for the application, fits perfectly into a stock injected hanger too.
Really? I thought TBI motors ran at less than 20psi, with the Vortec, TPI, etc. motors running >45psi?
Doober said:That's cool I thought you might've meant '96+, those pumps are higher pressure for the SFI setups in the Vortec engines.
