Hello,
New to the forum, picked up a 78 Malibu last month. Plan is to LS swap.
The engine is:
2011 L20 4.8 VVT engine - DBW
4L60E 2wd transmission
Intact stock harness/ECM/Throttle pedal/Accessories
The car:
1978 Malibu Classic - 74k original miles
Maroon and Red vinyl
Nice interior but smells of 30yrs of barn storage and mouse hotel - buckets and console shift
Engine - 305
Tran - Metric 200?
Rear axle - 7.5 with aluminum brake drums
Factory AC car - stock suspension.
FX spoilers ground effects kit? That's what's on the boxes.
The original owner got too old to drive it, gave it to her daughter who had a small fender bender, they then sold it to the gentleman I got it from. He never drove it just put it in the barn to one day fix.
Engine swap plan:
From what I have read you can use Sphon engine mounts and retain the stock truck pan and accessories. I want to keep the VVT as HPtuners allows for tuning with it. If the truck pan wont fit I have read that the CTSV pan is a good choice. I called and asked Holley if their pan is compatible with VVT and they said no.
Radiator: An aluminum one with an e-fan would be ideal. I heard dodge intrepid fans are a good fit on a stock radiator so maybe a new OEM and those fans?
Headers: So many choices, most likely long tubes, ceramic coated so they don't look terrible after 1 week Headman/Holley/etc....
ECM: Tuning with HPtuners
Engine harness: PSI conversions or send the stocker out to be modified? Thoughts?
Fuel system: Tanks Inc. tank, and LS swap plumbing, TI Automotive pump (Walbro).
Trans mounting is simple with the cross-members available today - either Trans Dapt (Headman Headers) or Holley for this one. Unless someone knows of a better option.
Rear axle: I am trying to get my hands on a 8.5 and do a LT1 rear brake conversion on it with the Flynbye brackets.
Got a set of s10 blazer front spindle and calipers from another buddy that has been saving stuff.
Suspension: will get new shocks, lowering coils, and stock replacement of worn parts for now. Would like to do a pro-touring style suspension later on.
Body: I am undecided which way to go. Its not terrible surface rust mostly, but after power washing the years of dust off i noticed the driver floor pan has some holes so a replacement panel will need to go in. I am gutting the interior anyway to try and get that mouse smell out so would be the perfect time to do it.
Interior: I plan to keep the red, going to try and get the seats re-foamed these covers are in great shape its unreal. The dash is un-cracked and all of the panels look in good shape. New seals, under-layment/sound deadening and carpet if necessary will happen.
The engine is:
The car:
Engine - 305
Tran - Metric 200?
Engine swap plan:
