Hey T5,
From what I gathered on using an adapter plate you have to change to the longer Viper input shaft to compensate for the thickness of the adapter plate,besides I got everything including the master cyl,braided hose,slave and then the flywheel back,
eventhough the clutch works backward it seems like a pretty good set up as I don't remember hearing anything bad about them,
and like I said If I had the later engine I could use the LT1 flywheel,I got a pretty decent deal on it and well I didn't like the fact I had to buy an expensive flywheel it was either that or a special bellhousing as Wildman is suggesting or the adapter plate or sell this one and you can buy one for a couple grand give or take that'll slide right in there so since this one (T56) is destined to be
behind a daily driver engine (Tuned Port 267,stock 6 for now) I decided to go with the flywheel as I think it should work just fine and It kinda adds up to one of those six of one,half dozen of the other kinda deals,when you modify cars it's going to cost you money and that's really all there is to it!! Thanks for the suggestions though!! KillerDave
