sleepybu
53
18
8
52
Fired up the bu today, pulled it out side.
I put a new master cyclinder on a few weeks ago, bleed the brakes the peddel still goes to the floor,they work but i don't think i'm getting full brake pressure,i had the same problem with the og mc.
Anybody have any iders?
78elk
1,294
81
Mountain Home Id
I started up the 78 Elk again today and it ran great. I hope to get the Sniper EFI system installed, but due to family get together it might be a while.
4,665
32
What technique did you use to bleed the brakes?
Did you first bench bleed the new master cylinder?
Did you then gravity bleed each of the wheel cylinders/calipers?
Did you then pump the pedal to bleed the remaining air? or use a vacuum pump at the cylinder/caliper to bleed the remaining air?
The new master cylinder could be bad.
sleepybu
53
18
8
52
Thanks for the responce,
I bolted the master cyclinder to the booster on the car, installed a bench bleeder kit, pumped the peddel alot, then hooked up the lines, and maybe a week or two later got some help to pump the peddel to bleed the brakes.
I may take the MC off and bench bleed it (properly) and rebleed the system.
The MC is a rock auto "ac delco" peace made in china (boo). Had to order it from there cus i could not find one in canada!
