I put a 87 4.3 with the 229 2 barrel intake, distributor, and exhaust manifolds in a chevy luv before and it ran great.
mhamilton said:v8s10dave said:distributor will work.
The 229 dist is semi-odd fire, 4.3L is even fire... you need a 4.3 distributor.
83 MALI WAGON said:I found a 85 4.3 with the 4 bbl and it has a 400 transmission, it came out of a chevy truck. will the 400 transmission fit in my malibu right up without any modifications or what mods will I have to do?
its the original transmission off the truck I think. the guy said i could have whatever else off the truck i needed so i was going to get the driveshaft, radiator and transmission crossmembermatty man said:You will need a new transmission cross member I do believe, possible drive shaft reduction, look in the tech section here and the dimensions are in there I think, thats a lot of transmission for a V-6 you will lose a lot of engine power just to drive the 400, are you planning on towing? Matty man 8) you will never have to worry about destroying that transmission though!!
the radiator and crossmember won't work, the driveshaft yoke will if it is a slip yoke83 MALI WAGON said:its the original transmission off the truck I think. the guy said i could have whatever else off the truck i needed so i was going to get the driveshaft, radiator and transmission crossmembermatty man said:You will need a new transmission cross member I do believe, possible drive shaft reduction, look in the tech section here and the dimensions are in there I think, thats a lot of transmission for a V-6 you will lose a lot of engine power just to drive the 400, are you planning on towing? Matty man 8) you will never have to worry about destroying that transmission though!!
it is an 85. how do i tell the difference between a 375 and a 400? are 375 desireable?80ECLT said:83 MALI WAGON said:I found a 85 4.3 with the 4 bbl and it has a 400 transmission, it came out of a chevy truck. will the 400 transmission fit in my malibu right up without any modifications or what mods will I have to do?
IIRC thats a TH375 trans. Im guessing 86 87 fullsize P/U??
