In a Malibu(2-door or possibly a wagon if I can find a clean one).
Setup 1: Rods/Pistons in an Iron 6-liter(Pump-gas compression, <11.5:1). Stock L92 heads with a nitrous cam, carb conversion, and 2 stages spraying 3-400 total.
Setup 2: Rods/Pistons in an Iron 6-liter. Stock heads, smallish turbo ground cam(Speed Inc T1 probably), flipped truck manifolds, s400 turbo, megasquirt efi, stock intake(or LS6 intake).
They would both probably go the same speed/ET. I've been thinking about the turbo setup for a while, but I've been starting to consider a nitrous setup as well. Nitrous would be a little easier to tune, but I think the turbo setup would make more power in the long run. Up the boost or go to the 80mm s400 upgrade and it's making enough power to break the stock crank/block.
I'd probably have the same amount of money into both...Mainly due to the turbo being around 600$ and using stock truck manifolds.
I don't know.
I don't know.
