10 bolt set up
Trying to set up a 10 bolt rear for a friend...having troubles. Any help appreciated. Here is what I got. 10 bolt posi - going from 3:23 to 3:73 - Richmon gears. Factory pinion shim was .037". I have tried differnt pinion depths and have gotten the best pattern with .038" pinion shim. I have .010" of backlash and pics of the pattern are below. They don't look to good to me, however any move I make gets much worst. Car will be street driven and dragged hard at track...auto nitrous small block car. Suggestions? Thanks!
scuba_steve's_bu
440
Rock Rapids, Iowa
we just did this whole routine last weekend. what we ended up doing was taking the grinder to one of the shims (opposite bearing side) and made it fit. probably not right but made it work. hopefully it holds up. [-o<
After seeing this pattern any suggestions on which way to move anythng? Thanks~
