Want to swap in a CS144 alt in the 4th gen Monte and found out that the mounting bolt spacing is wider for the CS144, by about .71 inch. Asside from shimming the existing mounting bracket, at the intake manifold, is it possible to use the early mounting brackets like that used in the Malibu? Believe that the Malibu,'s alternator has a wider spaced bolt hole location, than in the "87 Monte.
Thanks for any response.
