12 bolt sway bar ?
forty
269
south sub's of chicago
Hi guy's,Will my 12 bolt work with a 1 inch sway bar made for a g-body or a-body,Just checking before i order the wrong one thanks
UMI Sales
254
Hello
Yes a 1 inch rear sway bar will work as long as you are using the G body lower rears. Below is a link to show you what all UMI Performance has to offer. As far a that particular rear end sway and sway bar.
http://www.umiperformance.com/catalog/index.php?main_page=index&cPath=8_60_68&zenid=surp2nt5qhol3lujpsj3a83sj3
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_66&products_id=75&zenid=surp2nt5qhol3lujpsj3a83sj3
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad :D
malibulvr
1,929
Pensacola, Fl. 32526
I had only found a 1" rear sway bar available to fit the Gbody car, but then I did find a 1 1/8" rear sway bar kit made by Suspension Techniques and purchased it from JEG'S. It's made for the 68-72 Chevelle. The only difference is the space between the mounting holes in the sway bar is 1/2" off. All you have to do is elongate the rear mounting holes in the sway bar and it will bolt on.
http://www.jegs.com/i/Suspension-Techniques/876/51050/10002/-1
Sortly after I purchased mine these became available on Ebay. It's a monster sized 1 3/8" rear bar that will bolt on.
http://www.google.com/url?q=http://cgi.ebay.com/ebaymotors/1-3%252F8%2522-G-Body-Rear-Sway-Bar-Buick-GN-Monte-Carlo-78-88_W0QQitemZ150366583206QQcmdZViewItemQQimsxZ20090818%3FIMSfp%3DTL0908181510001r30873&ei=Z52NSqzTII7ysgOs2PTcCQ&sa=X&oi=spellmeleon_result&resnum=2&ct=result&usg=AFQjCNGbs7le-twt7uZ2MI6nCHmQWDWtoQ
