12 inch wheels
Larry
259
Michigan
Mike seems like you will hit the frame if your going to hit the tub I have a big notch and with the 295DR on a 10" its scary close.
i am running 29.5 x 10.5 on a 10 inch wide rim and I needed to notch the frame it only needed to be notched slightly but I notched it alot in case I ever want to go bigger or run a huge drag radial. I am running a 4.5 inch back spacing with weld alumistars
bustedknuckles
577
johnson city, tennessee
i got a good deal on a set of 15x12 welds so i bought them and used 295's these had 6 in backspace and the problem i had was they rubbed the bottom of the shock mounts. the mounts with that much backspaing actually set the shock mount about 1 1/2 in inside the wheel grinded slightly and they worked and looked great . did do full notch and trimmed lip a tad. like everyone else, you would be happier with 10's
