355 Harmonic Balancer
Shawn F.
209
Charlotte, NC
I am trying to get my 355 engine done to drop into my daily driver 1980 El Camino but still having trouble deciding on the last few parts. It's a basic 355 with flat top pistons and Vortec heads. Cam is still yet undecided but will be a basic low torque street cam. Anyways I need a harmonic balancer but have no clue which to go with... Any recommendations?
Is it worth spending $200 or more on one or stick with a basic $60-$80 one? Which brand would you guys go with? Also I see internally balanced which of course is stock and externally but do not understand the whole external balanced? Any information on this would be greatly appreciated!
Just get a quality internally balanced unit. If you're racing make sure it's SFI certified.
Shawn F.
209
Charlotte, NC
Timmy, thanks for the info! No racing here, just daily driver and work vehicle. Summit has a flywheel and 6 3/4" harmonic balancer kit for about $130 that I may get for their 290HP crate motor. Will this work fine? I was told to not get the 350 H.O. flywheel and balancer kit because it's a 1 piece main seal and there is a difference with the flywheel having a weight to counter for the seal.
If this $130 kit will work then that is what I will go with and be done with this part.
For a DD that should be fine as long as your 355 has 2 piece seals.
bracketchev1221
1,111
Mountville Pa
Look into the Pioneer brand on the Summit website. I used one of their street/strip ones, that was degreed up to 90 degrees. I am running a 425 hp 355.
