5th gen El Camino tach issue
78elk
763
Mountain Home Id
I'm having an issue with the clock and tach. The clock works fine, but the tach is at 6000 rpm at idle and when off. How do I trouble shoot the tach?
78elk
763
Mountain Home Id
I figured it out. I couldn't find the proper wire to plug the distributor into. It came unplugged when I pulled the speedo cable out.
B Rear window(5th door)weatherstripping malibu wagon Interior Tech 3
8 GEN V 454 Swap ? Drivetrain Technical 9
Time Warp Which BBC gen IV oil pan Drivetrain Technical 12
shvrolay Vintage Air Gen II Heater with Defrost 506101 Interior Tech 26
R Do pace setters headers for a 4th gen camaro fit a GBody? LSx Tech 3
Apathy93Z Anybody use 3rd gen Camaro mirrors? Autobody/Paint Technical 1
B.G. Kent Moore Gen 3&4 LS engine tool kit LSx Tech 0
daveybtv 2nd gen Camaro spinbdes on a g body? Suspension Technical 6
ROCK! 4th gen camaro wheels on my 81 Malibu? Wheels/Tires/Brakes Technical 2
8 Anyone used Moroso GEN 1 solids with their adapter mounts? LSx Tech 7
T BB Chevy Gen IV cylinder heads on Gen V block Drivetrain Technical 1
E "GEN" dummy light on all the time..... Electrical/Wiring Technical 2
D How many are running a Gen III or later motor? LSx Tech 3
V Correct GM bell housing part number 1987 El Camino Drivetrain Technical 3
DOUG213XRJ Malibu El camino front air dam questions. General Discussion 5
DOUG213XRJ Daily broke down, So out came the El Camino General Discussion 5
7 78 El Camino plastic chrome horn trim Interior Tech 2
B 1980 El Camino Carb to TBI EFI Tech 3
R 79 El Camino 12 bolt swap rim and tire Questions Drivetrain Technical 2
D G BODY EL CAMINO DRIVESHAFT? ????'S (700R4) TRANS Drivetrain Technical 5
G Malibu/El Camino Door Skins Autobody/Paint Technical 6
N Rear springs for 83 el camino Suspension Technical 0
9 Who has a dual exhaust kit for a 87 El-Camino Drivetrain Technical 0
V Vintage Air A/C for El Camino or G Body??? Interior Tech 2
flatblack79 El Camino Door panels in Malibu? Interior Tech 4
T how to make an el camino hook on a budget? Suspension Technical 2
A 1984 El Camino and 84 Malibu Electrical/Wiring Technical 2
Apathy93Z How far back for later Camino mirrors on 79 Malibu door? Autobody/Paint Technical 0
90Gabe El Camino 700r4 Jegster X-Member Transmission Technical 0
7 El Camino quarter window felt replacement Autobody/Paint Technical 1
M el camino 1/4 glass molding pic Autobody/Paint Technical 0
Bald Menace el camino interior parts? Interior Tech 0
81elcamaro 81 EL CAMINO LS1 LSx Tech 19
8 Tach stoped working on 84 El camino.. Any ideas? Electrical/Wiring Technical 1
abigda BBC El Camino wheel hop Suspension Technical 6
D El Camino EFI EFI Tech 4
B turbo el camino vid Power Adders 125
R 400 trans in 79 El Camino Drivetrain Technical 20
E El camino tow rating LSx Tech 11
A 73-77 el camino rear Drivetrain Technical 1
Darwinskeeper Fiberglass parts and the Daily Driven El Camino? Autobody/Paint Technical 1
A El Camino SS nose conversion Autobody/Paint Technical 7
M 275 60 on an El Camino. Wheels/Tires/Brakes Technical 1
elsky79 el camino wheel wells? Wheels/Tires/Brakes Technical 1
Blackwizard22 El camino same as mailbu in wheel bs? Wheels/Tires/Brakes Technical 3
N tire size for 85 El Camino Wheels/Tires/Brakes Technical 2
78Camino El Camino Rear slick size.... Wheels/Tires/Brakes Technical 3
Similar threads
