700r4 with column shifter?????'s
dickeymoore
818
Atlanta,Ga.
I have a 1980 Chevy Monte Carlo with a 350 automatic transmission with column shift I'm wanting to replace the 350 transmission with a 700R4 with the stock column shift is there a way I can retain to stock column shift to work with all the gears with the 700R4 transmission,will the stock linkage bolt to the 700r4 trans or what? THANKS
78elk
961
41
28
Mountain Home Id
I haven't did that. But I know it can be done. You would get a different gear indicator for your dash. I was going to do the same with mine, but the linkage was bad. So I put in a B&M floor shifter.
melloelky
3,620
14
mass
i think nillabu did his column with a 200r4.yes it's a different trans but it's still a swap of the 4-speed nature.maybe he can shed some light on your idea.
melloelky
3,620
14
mass
You were rite the first-time it's nillabu.pm him
malibuguy
3,775
Finksburg, Md
I used a lokar rod linkage kit to make my 200r4 work on the column.
If I were to do it a again...I would have used the cable kit instead ( i didnt know they offered that at the time)
With the rod...wot in 1st gear would bump the trans into 2nd if I didnt hold it.
Im going to attempt to make a cable contraction to use my column shift with the lexus trans
dickeymoore
818
Atlanta,Ga.
I just got the setup from a g body with a 200r4 column shifter and it works getting all gears with a 700r4 transmission using coljmn shifter
Similar threads
