What kind do you want? They sell many shank sizes that will interchange and or you can always redrill the stud pilot holes larger to use different size shank and thread combinations. Jim
Metric studs are fine. I have raced stocker 7/16 20 thread count to 11.90's which is smaller than the Metric studs. The metric is between the 1/2" and the 7/16" So I would not hesitate to run them. You can drill the axles on the car if you are careful. Takes steady hand... Make sure you get a good press fit atr least 5-10 thousands . You can alway enlarge BUT you can not put that material back. Take it slow and measure twice and drill once... Take care. Jim
