81 malibu proportioning valve
frost1085
144
Fort Wayne, IN
hi, im wanting to no if i cant remove my proportioning valve/ junction box thats mounted on the frame of my 81 malibu and replace it with a booster/ master cylinder mounted one. mines have a crack in it so i have to change it. thanks
it has drums in the rear and disc in the front its stock
The frame is cracked, or the combo valve? I don't quite understand why you need to relocate the valve.
frost1085
144
Fort Wayne, IN
just the valve is cracked and leaking i wanted to mount it up top for ease of access. plus i have a diffrent frame and the screw that holds the valve to the frame is brokin off into the frame its the one towards the master cylinder
and once i get my exhaust done its probably going to be hard to get at.
frost1085
144
Fort Wayne, IN
and the tip of it is sitting up against my headder i grinded it down a little but its still on it. thats not the part thats leakin though.
Got ya. Master Power Brakes sells the combo valve mount kits to put it under the Master Cylinder.
