81 malibu w/ 1968 12 bolt?
buying a set of 8" welds for the car and wondering if anybody is running a wider (68 and up 12 bolt and what the used for offset) going to run a 28x 10.5 tire, but dont want the skyjacker look i want to tuck the wheel in the well best i can. no notch w/ rolled lip. thanks in advance for your help
GreenDragginBu
6,293
N.E. Ohio
5" b.s. I ran a 15x8.5 with 5" b.s.
welds are only coming in 4.5 and 5.5 backspace and they go from 8 to 10" in width.
Perryk
1,055
montana
rims
I have an 84 Regal and got 15x8" with 4" backspacing on the stock rear. The tires are sitting perfectly inside wheelwells.
If you add 1.5" to each side for the wider rear, then add the same to the wheel backspacing.
Provided the 12 bolt is 3" wider, a 15x8" with 5.5" b.s would be perfect.
Perry
ILLEGAL REGAL
7,160
Tinley Park,IL
Re: rims
Perry
that's what I had also, but I don't know if they'd fit without a notch. I don't know how far the frame come out to guestimate. My new wheels are 9" 5 7/8"bs lots of room still and they tuck.
Perryk
1,055
montana
hmmm
Illegal,
If you are running 5 7/8" b.s then a 5.5 should fit without a notch...thats on my Regal anyways.
I just gotta figure out how to get my Regal lowered in the back with my tucked Drag radials....
Perry
p.s. I do KNOW that anything less than a 5" b.s with a stock width 12 bolt will stick out.Good luck.
thanks for the help guys! i fit up a rally i had w/ a 275 on it and did some measuring and 8 w 5.5bs is the deal.
