alignment shims
melloelky
3,654
31
mass
i haven't had my car aligned in many years and was wondering roughly how much does get added?I'm not lining my car up at home but just wondering how much of the upper control arm gets pulled in toward the frame?roughly.thanks.
You need to actually measure, or at least use a level. Cut a piece of 2x4, etc. to fit in the lips of the wheel itself, then check with a level. It won't be perfect, but it will keep your tires from destroying themselves prematurely.
melloelky
3,654
31
mass
thanks,I'm not actually driving the car or anything the amount it gets pushed in and out of the shop there's no tire rubbing.just wondering that's all.thanks.
1978AL
108
FLINT MICHIGAN
that's your camber adjustment..be sure the car, especially the front area, is 100% complete..
melloelky
3,654
31
mass
thank you.i know what it is,i know what it does,i'm not going to be actually putting any shims on it,i know the car has to be @full weight all i'm asking is there an inch or so of shims front/back on the control arm there?
1978AL
108
FLINT MICHIGAN
sorry man...not sure i follow? are you asking whats typically there in stock form or?
melloelky
3,654
31
mass
yes please,is it usually a large stack like 5-6 bigger shims?sorry about that.
