Any one using LOG WORKS
starfire350
331
Dallas, TEXAS
I set up my innovate wide band o2 last night with a ssi4 sensor controller. I have only installed the rpm signal from my digital 6 box to the ssi4 so far and o2. It is reading the air fuel mix and rpm but the rpm is doubled its ideling at 800 but the logworks reads 1600. Where do I change the settings I dont see any options in the channel settings window?
Thanks
schmidtj86
58
China. San Luis Obispo. Iowa
Use the LM Programmer software (and power up the SSI4 alone (disconnect other daisy chained devices) - read the manual at about page 21), and change input 1 to the right settings (RPM, max RPM Range to something reasonable like 6500, and the cylinder count to something else). It might be picking up some noise, too, but try a different cylinder count setting first. I don't know the correct setting for your MSD though.
starfire350
331
Dallas, TEXAS
I couldnt find any where to change the cylinder count but that makes since Ill look around some more tonight.
