I've identified that part of my suspension problems at track were due to my TRZ ARB INTERFERING WITH THE LARGER THAN STOCK DIAMETER moroso trick springs car had stock 6cylinder rear coils when ARB was welded in the solution seems to be replace rear coil springs my choices are replacement6cyl coils or cargo coils anyone had good ex Erie Cretan racing with cargo coils my car is2drmalibu just need to replace rear coils unsure of cargo coil for trying to 60' any input or should I just get replacement coils for 6cylinder Malibu my car does not carry heavy loads no back seat trying figure best stock diameter spring to match with new drag shocks get this thing out the hole with drag radials the key is getting weight transfer a
Not sure how stiff cargo coils will help plant tires any help who has had success with cargo coils just need advice to make right purchase anyone having success with stiff cargo springs if so w hat ET are you running Iplan on using drag shocks just curious if cargo spring will cause too much rake to get any weight transfer they are listed as variable rate just wondering anybody having success with the cargo coil at1320
Code:
