anyone use a 5" b.s?
Perryk
1,055
montana
Just curious if anyone has ever had any luck with a 5" b.s, wheel on a stock width rear?
I know a frame notch would be needed but can ya still fit it?
Thanks
PErry
Supe
15,116
Charlotte, NC
You'll need a very heavy notch, and at least with my wagon, it'd never work without a mini tub.
Perryk
1,055
montana
hmmm
How bout a light notch and a wheel spacer?
Are they safe for 450 hp range with drag radials?
Perry
wheel spacer AND 450 hp range with drag radials is combo not suitable for my safety needs !
my 0.02$
4doorbu
1,877
south jersey
i have 15x10" rims with 5" bs. with 28x10.5W's(same as 325/50 radials) pretty large notch, fit fine with stock width now have 7/16" off each side and i got about 1/2" between the frame and tire.
Turbo1dr
2,223
New Bern NC
www.turbomalibu.com
Here is some pictures of 28x10.5x15 MT slicks mounted on 15x9x5.5.
Below you can see how much I cut the frame for the frame notch. You can see the black "cut" mark across the top of the frame.
Rear of the car was sitting on a small hump in the yard in this picture.
