Brake application issue since installing c-clip elim's
80montecarlo
1,123
cloverdale b.c. canada
So last winter I installed a set of Moser C-clip elims on 7.5" and ever since I have installed them I cannot get my drum brakes to apply at what I would consider anywhere near enough. On the jackstands it will barley even hold at idle. Any ideas on what this may be causing this issue??? I have them set up so that there is so much drag that I can barley turn the wheels.
StreetBu
4,158
3
Upstate NY
Re: Brake application issue
Is it bled out? Sounds like air in the lines still...
80montecarlo
1,123
No I have bled and re bled and then re bled again, then to boot I got my buddy to come buy to check to make sure that I am not delusional and missing air and he said that the fluid looks perfect but cannot figure out the application issue. This all started when I went to the C-clip Elims, my brakes worked fine before now they barely do. Could it be that I have to machine the top of the c-clip elims to add additional clearance for the spreader bar? ](*,)
Any ideas are appreciated, wouldn't mind getting to the track next weeked if my foot heals up enough to wrap a throttle pedal. [-o<
StreetBu
4,158
3
Upstate NY
If something is hitting on the brake shoes or hardware, then that will def cause issues...Kinda hard to diagnose that without seeing it though. Sorry I couldnt help more....
80montecarlo
1,123
I should also mention everyting is brand new other than the spring on the spreader bar and the oblong shoe holder above the wheel cylinder, new shoes new drums new adjuster and harware kit and new spreader bars
80montecarlo
1,123
bump
80montecarlo
1,123
Removed the E-brake assy and it works just awesome even without adjusting the shoes yet, I believe that the spreader bar was binding against the c-clip eliminator, as well i noticed that the stud above the wheel cylinder that the shoes rest against was out by 90 degrees I dont know if that affects the opperation but I rotated it back to where it is supposed to be
Thanks for the input guys
80montecarlo
1,123
curt377x said:
Do you have to run the spreader bar when you take out the E-brake?
i didnt, going to go to four wheel disc this winter after the season, brakes still arent the best but I do need a parking brake
