Carbed LS Swap?
Deuce4935
341
Chicago, Il
I have 98' F-body LS1(complete/all accessorie), I'm going with the carb intake, ZO6 heads/cam,MSD6010, and BG carb.I need help with mapping out the fuel system. Can anyone tell me what fuel pump and regulator are needed for supply and if a return line needsto be installed?
Also, what has to be done to hook up 400 or 700r4 trans, and which converters are used?
Deuce4935
341
Chicago, Il
No knowledgeable replys to this thread huh?
T5MalibuWagon
1,386
Fort Worthless TEXAS!
Man all you need is a pump that will put out 6psi, plug it in you stock line, its a carb.
X2 on the pump/carb...
On the converter, you may be able to use the OE style 4L60E converter from your car (so long as you use lockup, not sure what all is doable/required there) for the LS motor. Horsepwraddict(sp?) can probably point you in the right direction, he seems happy with the converter he got.
