Clutch Fork Spring Clip Rivet
4,770
39
Do you think the rivet that holds the spring clip to a clutch fork is a standard hardware store item?
The hole in the spring is just a tad larger than 3/16 inches in diameter (about 0.21 inches), so I assume the rivet is 3/16.
I would rather not use a nut/bolt combination.
shvrolay
Yes they are Marc.......I've also used a steel pop rivet. There's really no stress put on the rivet, usually the only time that spring breaks is if the TO bearing was installed incorrectly.
