dash lights
goldie
392
chicago
www.geocities.com
no dash lights. but the head lights come when I pull the knob but no dash. went to the fuse block no power coming from the 5 amp. so I used wire to power them up it worked but no power from the green wire on fuse five. why?
Not to be insulting, but is the dash light dimmer turned down? If not, it may be bad.
goldie
392
chicago
www.geocities.com
I have turned that knob about twenty times.. I went to the fuse no power on the left side which should be constant power. So I used jumper wire to give the right side of fuse power they'd worked.
Doe you have tail lights/turn signals? If not, check the 20A tail light fuse. It feeds the dash light dimmer.
IIRC, just the "B" fusible link. IF that was bad, you'd have no clock, courtesy lamps, lighter, headlights, tail lights or signals.
Sounds like the dimmer is shot.
4,674
32
Sometimes it is due to dirty contacts on the socket behind the cluster.
If you find there is power everywhere, but not getting to the bulb, remove the cluster and clean the copper contacts on the plug and the printed circuit board with a pencil eraser.
