Im sure this is a repeat of alot of previous posts but here it goes...
The car is a 79 malibu classic origionaly with front disk rear drum...now i have a ford 9" rear with strange disk brakes that i set up myself...i did not change anything with the brake setup other than putting the rear disk on. What will i need to change to make his setup work? Right now the car stops ok enough that iv been running it at the track but obviously the rear brakes dont work...is a prop valve all i need to make the rear brakes work? Any help would be appre iated...also been looking into manual brake setups but would like to do a heap quick fix till race season is over...in a points hunt right now at local track
Thanks
Thanks
