Drop spindle problem-ball joint related
albertaborn
37
Hello I purchased some drop spindles from a swap meet for my 1980 malibu. They were advertised as g body drop spindles. The spindles look exactly like stock except dropped of course but there is a difference in the ball joint holes on the lowers. The new spindles seem to have a larger ball joint hole/taper when when trying to install. The only identification it says on spindles is "RHLH 64-74 "stamped . Other thing I noticed is dust cover holes are different threads but I'm already tapped them to metrics to use factory bolt. What do I do about lower ball joint hole being different?
Unfortunately, it sounds like the wrong part to me due to the dates on them. Pontiac & Chevy had a G body back then...
albertaborn
37
Everything else is the same but the hole that was taper bored into lower spindle. Bummer there is no special ball joint.
albertaborn
37
So no special ball joint to make this work ?
