ECU removal???
slownugly
31
Cookeville, Tn
Hey I was considering taking my ecu out but wasn't sure exactly what all it ran. My motor has all mechanical gauges and none of the smog equipment. Can I just pull it or do I need to keep it? Thanks
Is you engine all factory? If so, the carb, ignition & some other stuff is tied in.
slownugly
31
Cookeville, Tn
No the engine is not stock and the carb has a manual choke. Do you know what wires run to the ignition and what they run exactly? can I run without them? thanks
slownugly
31
Cookeville, Tn
Scratch that...hahaha...I removed the kick panel and realized that the ECU had already been removed by the previous owner. So I guess it will run with out it. :lol: Thanks for the replies regardless.
