Edelbrock RPM air gap manifold
mebe007
291
Eastern Virginia
i dont have the airgap, but the standard rpm and it clears just fine with a drop base and 3" element. they are the same runners on both manifolds. so install with confidence. it should fit fine.
HP JUNKEY
1,093
Buffalo.NY
I ran the Edelbrock RPM for 1 season and then switched to the RPM Air Gap on my 355, used my 750 Holley, Drop base 3" element air cleaner and there is no clearance issues with my stock hood, I even tried a 1/2" spacer under the carb last year and my hood still closed fine. No spacers in the rear of my hood and I removed the under hood insulation. Works for me!
Direct from Edelbrocks web site, they say the height measurement of the RPM Air Gap #7501 is the same as the non-air gap RPM #7101. Here is the link
http://www.edelbrock.com/automotive_new/mc/manifolds/chevy/rpm_air_gap-sb.shtml
madmaxx57
237
DURAND IL
well i revisited mine to see if mine would make it without the rear spacers..it will not..not sure why but it wont??..i have new poly motor mounts..idk..i pulled the stud and left the air cleaner on..hood wont close..hits in the front about 3/8 before it closes?? hmmmmm
Damon
1,655
Philly Area
That could very well be the reason why.
madmaxx57
237
DURAND IL
yea i'm thinking it must be...as it looks like i have the same drop base as 1980PontiacWagon..maybe after those mount settle (?) a little maybe i can remove the spacers??
SSedan64 said:
Those Poly mounts are known to be thicker, Trans mounts also. They don't settle like Rubber either.
I can't see how they're thicker. They reuse the steel halves from a stock mount...
4,761
Yes, but the cushion floats inside the shells. I would hope that the initial poly assembly matches closely to the original rubber assembly, but will not settle/squash like the rubber one, which may result in the engine sitting higher in the bay.
melloelky
3,654
31
mass
Tommy&T5 both have good points.in my 82 camino i had those poly insert motor mounts and trans mount w/my rpm'ed air gaped sbc.i ran that same edelbrock drop base part store air cleaner with a one inch spacer and had no clearance issues with a holley or the carter carb.i can't help but wonder what variables make up for the hood interference :-k on this one.
Maybe. I don't recall much settling of stockers. COuld be wrong. I have poly mounts & I'm going to run my 454 witha stock GM HP dual plane & Cowl Induction. I hope it all clears...
TOmmy
