engine wiring
lue
37
Long Beach, Ca
Hi Everyone,
I need some help connecting the wiring on my 79 Malibu. It originally came with a V6 231 /with elec choke. In place is going a 350 /with elec choke. With some help, i was able to figure where the alternator and starter wiring went to. But i'm kinda stuck with the choke part.
The way my v6 wire harnest is;
The choke connections has two wires. One coming directly from the firewall leading to the choke, then that same choke connector has a second wire leading to the oil temp sender, then to the starter.
Here is a picture of the 231 V6 passenger side where the oil temp sender is located. I also drew in red where the second wire coming of my choke would lead to the oil temp sender, then to the starter..
Should i wired the V8 the same way?
