Floor pans install pics anyone??
GreenDragginBu
6,293
N.E. Ohio
Just as the title says... anybody have pics of when they did there floor pans??? how they welded...Butt weld or lap welds?? did you remove the center seat mount piece and then reinstall or just bend it up???
GreenDragginBu
6,293
N.E. Ohio
Thanks for the link Betcha.
But does anyone have any experience doing this on a g-body??? Pics?
I'm about to dive into this soon on the el camino.
Just started mine will try and post some pics in the next day or two , yes had to cut center brace . lap jiont about a third of the way down on the drivers side of trans tunnel (best place to hide it ????) tried to use as many of the factory seams as possible . A 29.00 pneumatic flange gun from wholesale tools does wonders and a handfull of clecos (removable air craft / sheet metal rivets ) to temp panet in with and will more than likely tig/spot weld in but may use my mig
O. D. Showtime
2,850
Regina SK Canada
When I did my son's 81 a few years ago I did much the same as ROOSTER007 lap welds but I got luckly and didn't have to mess with bracing, when I do the 79, if I do the 79 I got a complete floor pan from a Cutlass and was going to use the factory seams wherever I could.
PAPPYC
Member
May 18, 2008
9
its not a hard job but its time consuming. just did pass side full pan in78 bu last winter that were doing for my daughter. bought the panel out of mich. have to look for co. name. it matches lots of factory seems, some i used some not. did about 1 inch over lap mig welded solid inside and spot weld under side. use seam sealer on all welds moisture is your enimie. just be patient fitting it it makes all the diff.seat mount i took loose and notched on top of hump to allow it to raise just enough welded notch back when done. done this type of work for 35 years and again be patient fitting it and you will be fine.
GreenDragginBu
6,293
N.E. Ohio
Thanks for all the advice. I gave up on finding them from donor cars and bought full LH and RH pans.
GreenDragginBu
6,293
N.E. Ohio
Hey Tom it was Northcoast Musclecar, they are local to me. Saleslady Becky was great help and can get just about anything for G-bodys. http://www.northcoastmusclecar.com/
P.S. the floorpans are Sherman parts
U Floor pans? Autobody/Paint Technical 1
fastrat350 ebay floor patch pans? Autobody/Paint Technical 6
STROKERBU G BODY DONOR FLOOR PANS? Autobody/Paint Technical 0
STROKERBU FLOOR PANS Autobody/Paint Technical 1
79ChevyBu floor pans Autobody/Paint Technical 5
H stock floor shifter cable? Transmission Technical 0
V Turbo350 column to floor shifter conversion? Transmission Technical 2
M Floor pan support brace assistance Autobody/Paint Technical 5
R 79 Elco soft pedal to the floor. Wheels/Tires/Brakes Technical 2
M Floor to firewall seam question Drivetrain Technical 3
83LSWagon Latex paint on interior floor? Interior Tech 2
P Automatic floor shifter (neutral safety and reverse light ) Electrical/Wiring Technical 4
D Tilt floor shift steering column... upper portion 'wiggles' Interior Tech 12
C brakes to the floor Wheels/Tires/Brakes Technical 5
widomkr79 brake pedal goes to the floor Wheels/Tires/Brakes Technical 9
R Wagon cargo floor removal. Interior Tech 1
44-bu Rotten rear floor Autobody/Paint Technical 8
U floor pan Autobody/Paint Technical 4
D Rear floor patch panel search Autobody/Paint Technical 1
7 Is anyone running a floor shifted automatic with bench seat? Interior Tech 9
G floor pan question Autobody/Paint Technical 3
3 Floor shifter for automatic Transmission Technical 3
jakedog Backup Lights, Where to hook up with Floor shifter ? Electrical/Wiring Technical 6
79ChevyBu Floor braces Autobody/Paint Technical 3
StreetBu Knock knock knocking on my floor Drivetrain Technical 7
B FLOOR PAN HELP Autobody/Paint Technical 2
S Switching from Colum to Floor Shifter Drivetrain Technical 6
M Any 1 in st louis that can remove and install new floor pan Autobody/Paint Technical 2
80Grand_LeMans Looking to seal up trunk floor. Autobody/Paint Technical 2
79izfine frame off / floor repair Autobody/Paint Technical 1
A no backup lights after floor shifter installed Electrical/Wiring Technical 2
Malibu Monte Ebay roll pans? Autobody/Paint Technical 1
7 non stock oil pans fitment / linelocks Drivetrain Technical 3
malibus~most~wanted th-350 pans Transmission Technical 3
StreetBu Oil Pans pics & dimensions - NOW A STICKY LSx Tech 3
A Air pans with cowl hoods Advanced Technical 38
D G BODY POSI REAREND INSTALL? ?????'S Drivetrain Technical 2
S Newer Camaro SS drive train in a wagon! IRS install? Drivetrain Technical 1
D balancer install Drivetrain Technical 2
D tach light wire install Drivetrain Technical 2
1 How to install steering column Interior Tech 3
M Carpet Install Question Interior Tech 13
D G Body Accelerator cable Install ???'s Drivetrain Technical 2
N 5" LCD Install Interior Tech 12
ALaRock Rear Coil-over spring install question Suspension Technical 11
woody31 install kit Transmission Technical 2
8 6.0 l92 swap almost ready for install in my wagon LSx Tech 3
Z Dash Pad Install?? Interior Tech 2
thumper Big Block wont start after install..... Drivetrain Technical 15
M Engine install question Drivetrain Technical 9
Similar threads
