Front Brakes Locking Up
gmtofd
716
Central Jersey
Seems like the proportioning valve is too much bias toward the front. The frt brakes are locking up much too easily.
Has anyone out there have a similar problem and could verify that it's the proportioning valve?
Thanks
malibudave1978
226
Houston, TX
Most likely not the prop valve, but if the low pressure switch was triggered, you could have just the front brakes working and not the rear. This may be your issue.
I don't know your tire or brake setup, but if you have skinnier and/or shorter tires on the front than the back, your front brakes will lock up easier as you have less contact with the road with a skinnier and/or shorter tire than a wider and/or taller tire.
A smaller bore master cylinder would create more line pressure. Stock size is 24mm bore diameter. A smaller 7/8" bore size was also available and came equipped on early manual brake cars. You put a manual brake master cylinder on a vacuum boosted car, you will have super sensitive brakes. Same effect will happen with upsizing to a larger booster or upgrading a booster from single to dual diaphragm.
Also, going with a caliper with a larger piston area over stock will also make your brake more sensitive as the clamping forces will increase with more piston area. Going from a stock single piston, to a dual piston Blazer setup will make your brakes more sensitive as the piston area went up.
Pads could also be a factor as the front pads could be more aggressive than the rears causing the brakes to lock up easier.
Bottom line it could be multiple things.
What is your brake setup front and rear?
What pads are you using?
What has been changed out in your brake system?
gmtofd
716
Central Jersey
Thanks for responding.
235-60X15's all around, semimetallic pads, the rear wheel cylinders were changed to those used on S-10s with manual brakes., the frt calipers are stock. The rear brakes are working as when the drums were pulled there was brake dust. Going to check to see what's the rear line pressure at. Suppose it would be good ito know what the pressure is supposed to be?
The master cly is still original after 230k+miles. Could it be internally leaking?
malibudave1978
226
Houston, TX
Sorry for the late reply.
I could be the master cylinder. 230K is a lot of miles.
I am not sure what the rear line pressure should be, but with 7/8" bore S10 wheel cylinders, your rear drum brakes should be more sensitive than the front. It makes me think there is air in the line or your shoes are not adjusted out enough, but since the master cylinder has 230K miles, I wouldn't rule the master cylinder out either.
If you do replace the master cylinder, I would go with a newer master. There is a right hand drive S10 master cylinder that should bolt right up. Check the link at the top of the Brake Forum on maliburacing.com
If I needed to replace my master cylinder, I would go with the S10 master cylinder from the link above.
