Front Clip Interchange?
shortbus57
18
Georgia
Have a olds wagon and would like to convert front clip to malibu due to me not liking the grille in olds! Will any year interchange to a malibu,.If so is it a bolt up process or major fab job..Thanks
4,665
32
A Malibu front clip will physically fit, but the body lines on the doors are not the same and the curve at the top of the door is a bit different. A Buick front clip will have the correct body lines, but not sure about the curve at the top of the door.
shortbus57
18
Georgia
thanks for info,..could you just chanhe the front header panel(where headlights are)to a dual headlight malibu??
shortbus57
18
Georgia
Well looks like im gonna leave it alone then!! Thanks for all your info and help!! :)
As far as being a direct "bolt-on" swap, Malibu front clips only fit on Malibus. The frame is longer on the other A/G bodies so the bumpers end up sticking out too far. Guys get away with it by collapsing the front shock bumpers...
Yup. The Malibu A/G body has it's own frame. The others are all known as "A/G Specials". The front sheet metal is longer, hence the longer front frame rails.
