I would like to know what fuel line you guys on your lsx swaps? I am going to use a corvette filter ,do you all use the factory steel line or go another route.
I ran -8 supply and a -6 return. I would just run a new line. Not so bad since you only really have one line to run since it sounds like you are using a returnless system. Just make sure your supply and return are closely sized.
I ran 3/8 hard line for supply and rubber fuel line for a return. But I have a truck intake and rails with an in-line pump, so my setup is a little different than yours. I also put two inline filters, one before the pump and one after.
