G body clutch fork in Lakewood Bell?
4,770
39
With all the welding you guys did to your 15000, you essentially made a 15015. The 15015 will work properly and you can use the straight "winged" fork to achieve the correct geometry.
4,770
39
On my website, I compare several compatible bellhousings. All have the fork ballstud in the same location as the Malibu bellhousing. The only difference is the location of the fork window. The Malibu bellhousing requires the unique fork; all others require the 14066235 fork, or equivalent.
http://garage-scene.com/t5-into-ag-body/t5_install_bellhousing.htm
This picture is about as close as I have to the installed fork/bellhousing.
