Holley choke question
Where do you guys hook the 12 volt wire for the electric choke and what size wire do you use? I got an intake with the carb and it has the electric choke and I just need to know what power source to use for it.
Thanks in advance
Larry
DOUG213XRJ
4,671
West, MI
For all my summer time cars i run it to the back of the alternater for a fast warm up.
DOUG213XRJ said:
spare time toys said:
Where else could it be tapped into under the hood?
78 and up G-bodys have a electric choke wire.
I checked into this and found it on a wire diagram I pulled up on the local library web site. Looks to be a brown wire coming from the alt.
Thanks Larry
80Grand_LeMans
1,249
Peabody MA
could you get that diagram up on here? Id like to take a look at it.
Thanks.
rjleiker
261
Derby, KS
Electric choke wires are just a switched power source, last time I checked. Just hook in a 14-16 guage wire to something that is switched power and it will power on just fine. As long as the power is switched on, it will heat up and unchoke in the appropriate time.
Let me know if I am wrong about this. This is how I found it out... I am kind of an electrical junky.
shvrolay
Thanks.
This is for a '80.......
Looks like it's wired off the oil pressure switch..........easier to do like rjleiker suggested..
HTH
