Horsepower estimate on new LS1
extremeracing
506
Kansas City
Ok, after letting a L92 escalade motor slip thru my fingers I scored a freshly rebuilt LS1 from a 03 corvette with forged pistons with valve reliefs, arp rod bolts ported 241 heads LS6 springs and oil pump, and a ASA Cam. it is roughly 10:1 comp with the milled heads. It came with a LS1 intake, 38# injectors, coils, water pump, brand new clutch flywheel, and a LS1 swap harness with f body computer. any idea what this motor will make for horsepower and torque? should I put in a better cam? I am on the fence about the asa cam as Ive heard both good and bad things about this cam. Thanks for the help!
80superbu
2,253
Colorado springs, CO
I'm guessing around 400hp. I'm working on a similar motor build for my V-8 Miata swap. My heads would be very worked over with something similar to an ASA cam and my engine builder is saying 450
extremeracing
506
Kansas City
I talked to the machine shop that built the motor and they said 425hp to the rear wheels. is there a better cam to get closer to 475 rwhp with out power adders and still be a reliable driver with decent fuel milage?
Deuce4935
341
Chicago, Il
The GM LS1 Grand-Am cam, I have to find my GMPP catalog to get the pt#. Beware, its numbers are 239/251, .570"/.570" on a 106. Mandatory, major valve reliefs needed and ported heads, preferably 243's, and a LS6 intake. Guaranteed 450+ rwhp.
littlefranks
543
pembrokepines FLORIDA
to get 475 to rear wheels you need to have 525-550 hp at the flywheel and thats not going to happen with a mild cam.
Roller406Bu
396
Elizabethtown Ky
those numbers there telling you seem way high to me...cam is mild like already stated..
Deuce4935
341
Chicago, Il
Go over to LS1tech and search around there for the cam i listed to ya. With ported 243's, ported stock throttle body, and the LS6 intake which should be on there if its an original 03' engine, you will see 450+ rwhp.
Roller406Bu
396
Elizabethtown Ky
who runs a 106 lob sep on a ls motor? never seen that...The guranteed 450 rwh seems far fetched to me..my ls1 in my ws6 has a g5x3 cam, fast 90 intake, 80mm tb, longtubes, ported 243 heads from livernois and made 436/400...which is respectable, 450rwh is aftermarket heads territory..
extremeracing
506
Kansas City
I have been told by several that headers and a tune are worth 50hp right off the bat. Stock horsepower on an 03 vette is 350hp so we are up to 400 flywheel hp and a good cam is worth another 50hp from what most say. I dont know what ported heads are worth for extra horsepower but the heads have also been milled and speed pro forged pistons have been added. I did get on LS1 tech and it seams similar motors with the same cam are making 450-485 at the flywheel, so 400-425 at the wheels. How do you tell a LS1 intake from a LS6? its the original intake off the motor but the guy listed it as an ls1 intake
