install kit
woody31
Hi there,,well i finally got my posi unit fixed, and i scored a set of gears on evil bay,,next up on the list is a install kit for a 7.5 inch,(yes i know i need a 9 inch)
anyways,,anyone have a recommendation on a kit,,ill need new bearings too i suppose,,,along with all the marking compounds,shims ect,,thanks for your time,,i appreciate it,,,cheers
SSedan64
948
MACON, GA.
Don't buy the cheap Kits, get a master overhaul kit with Timken bearings & Super Shims.
Yukon is one brand that uses them.
Axle Bearings/Seals:
Shop around for best deal.
MR Member >>
For a little more strength & ease of setup get a Solid Pinion Spacer w/shims instead of using the stock type Crush Sleeve.
woody31
thanks for the reply,,i have seen them from 79 up to 179-199
but they all look basically the same,,ill look around and gears should be here today,,gonna go check the mail,,be right back,,,cheers
hot dam,,the gears came in,,pics will follow,,
