Lookin for
malibuj
1,074
Lancaster PA
I'm not sure if this is the right place to post this or not????
I know there are some fast guys out there...that run the 8.5'' rear.....
I was lookin for some input,,, as to how some of you set up a back brace,,,Or if you really need to?????
I see jegs sells a kit.. that you would fab up and weld on.....
Also, do most of you guys have your axel tubes welded??????
As of now I'm pullin 1.45 60's without them welded ](*,)
Is this something I should look into having done?????Or not yet????
Any help or pics would great.....
Thanks everyone.....
malibuj
1,074
Lancaster PA
Hey Todd thanks for the help....
Would you or anyone else let this go for another season?????
Or should I have this taken care of asap, Like this winter????
Also I would really like to see any pics.....If you guys have them????
Thanks for any input on this.....
10secBu
4,284
Westminster, MD
While not mandatory, it is a good idea. The 8.5 has smaller axle tubes than say a 12 bolt or Ford 9", so it's not as strong to resist the bending forces.
Hard to say when/if you NEED it, but who's to say the housing isn't bent already and you don't already know it? Only way to tell is to remove the guts and have a housing jig slid into place to check. If it works fine now, it likely isn't making a noticable difference.
I put one on my 12 bolt when I first built it after seeing a '69 Camaro stock eliminator housing a local chassis shop removed. The axle tubes were severely bent, easy to see with the naked eye. I think the leaf spring cars are easier to bend the tubes though due to how the suspension ties into the housing.
malijuice
1,645
new york
i had one of these on my 12-bolt as well in my malibu i did not have one in my 69 camaro guess what i bent the housing
