Molly drive shaft question
78 blu
115
Rothschild WI
Quick question for the pros ... I have the opportunity to purchase a c molly drive shaft with 1330s at 52 1/8 (center cap to center cap)
mine measures 52 7/16 (center cap to center cap) will this shaft direct bolt to a stock TH 350 and stock 10 bolt 7.5 posi and if so
will the slight difference in length be an issue?
Thanks Jeff
TNTS79
1,252
Illiniois
Proper way to measure for a driveshaft. Insert yoke in to transmission completely, pull it out 1", measure center to center distance.
If you are going to a moly shaft why not 1350's? If you plan on sticking with the 7.5, I would not bother upgrading drive shafts - chances are the spider gears or axles will fail before the driveshaft does.
I don't remember what a factory 7.5 came with, probably something like a 534G or 1310, possibly a combo joint. Yoke on your 7.5 is not a 1330 unless someone swapped it prior to you owning it.
78 blu
115
Rothschild WI
thanks I just have the opportunity to upgrade at a great price and a 8.5 is in the future.
ecc_33
289
amanda ohio
That shouldn't be a issue. My car ran 11.80's with the stock drive shaft and rear end with a eaton locker and 4.11 gears. I wouldn't waste time or money on a stock rear. AS said above. When I put the ford 9" in my car I now have 1350 yokes and u joints on both sides of the driveshaft so I KNOW I won't break one.
Ed Cannon
1,682
Johnson City Tn
Ive been running a stock v6 drive shaft with solid 1310 U joints for years. Hundreds of Low low 10's and a hand full of 9.7's on spray. Not saying do as I do, but it works. If I had a 1350 shaft and yokes I would swap.
