motor mounts street/strip recomendations
madmaxx57
237
DURAND IL
what stock style motor mounts work best for street/strip..also will the v-8 mount location be the same as a v-6..this car i have is a v-6 originally ..thanks!
madmaxx57
237
DURAND IL
i also need to know what upper mounts (that mount to the block) fit the gbody..or will any do?..thanks
madmaxx57
237
DURAND IL
well yes and no..i figured out a few things about my car on my own(as far as location)..and i went with a stock style poly mount?...
Brian79
383
Wataga, IL
You got it. For a street/strip car poly mounts are the way to go. They will hold up and wont beat you to death with the vibration of the engine. You can go with solids but you will feel it. If you were going to take it to the track you could always do the el cheap o turn buckle to the motor/frame deal and remove it when you drive it on the street.
