Need help with converting console shifter... Pics pls!!!
tadow15A
New Member
Jul 10, 2012
4
How do you hook up a console shifter that has been converted from a column shifter... I am putting a console in and got rid of the column shifter however, now I'm wondering how do I/ where do i hook up the shifter cable to the shift linkage??? Any help is greatly appreciated!!! Need pics pls...
tadow15A
New Member
Jul 10, 2012
4
ok, thanx for the insight however, I have another '?'... so with this console shifter piece do I still need to run the column shifter linkage or can I just use this and the console shifter cable??? thanx again!
SSedan64
948
MACON, GA.
The linkage from the Trans to the Column also locks the Column which allows the key to be removed in Park position. You could turn the Column by hand but, it would be more work.
The Neutral Safety Switch and Backup Lights are also located there but, most floor shifters have those 2 switches mounted on the shifter frame/base.
Shifter diagram & parts:
tadow15A
New Member
Jul 10, 2012
4
thanx.... that was exactly what I needed to complete the conversion. I appreciate all ur help!!!
