SSedan64 said:Firetruck1 said:What controls the shifting? Does this transmission require a computer or just a kick down cable from the motor?
The TH200-4R doesn't require a Computer.
It will require a 12V+ source if you use a Lockup TC/TorqueConverter to activate the TCC/TorqueConverterClutch Solenoid.
It uses a TV/ThrottleValve cable which controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts. The function of the TV cable is similar to the combined functions of a vacuum modulator and a detent cable. The TV cable used with the 2004R trans should not be thought of as an Detent/Kickdown/Downshift cable. Adjustment & correct Bracketry is critical, too loose = Burnt clutches & Rebuild time.
How would I go about running and where to for the 12v for the torque converter? I plan to swap the 4.3 for a 350 with a 4150 Holley carb, what bracket would take care of this task correctly?
