My 2004R, no full throttle up shift, everything else seems more or less normal, governor issues such as missing spring, etc...??? :?
. The cable adjustment is right haven't checked pressures but the normal functions are so good I doubt that's a problem. I just bought the car, the transmission seems solid, everything more or less, works as it should except that I get no w.o.t. upshift in any gear, I can blip the throttle and it shifts fine. Judging from the shift quality I'm guessing there may be a mild shift kit or slight mods to firm shifts, but nothing radical at all, could even be a good stocker. Not having dealt with 200's much I don't have a lot of background. The engine is a mildly modified vin 9 307 Olds, '030 over, balanced, blueprinted, ported heads, 2" 350 intake valves, 350 exhaust valves, Performer intake port matched, .473/260 Comp cam.everything else seems more or less normal
