i come to find out that my rear brakes dont work because they are not getting any fluid. i took the lines off the rear distribution block to see if it was stopped up. i press the pedal no fluid. then i took the rubber line off from the hard line no fluid. then i took the hard line off porportioning valve and fluid came out from there when i press the pedal. could it be i have a porportioning valve or a stopped up brake line?
